Configures the maximum BPDUs transmitted per second.
| stpd_name | Specifies an STPD name on the switch. |
| tx_hold_count | Specifies the maximum number of BPDUs transmitted per second. The valid range is 1–10. |
By default, the maximum number of BPDUs transmitted per second is 6.
The transmit hold count is used by the port transmit state machine to limit BPDU transmission rate.
The following example configures the transmit hold count for STP domain r1 to five BPDUs per second:
configure stpd r1 tx-hold-count 5
This command was first available in ExtremeXOS 15.7.1.
